What is the purpose og Gauge Hatch provided in tanks ?
Gauge Hatch
Started by ayan_dg, Sep 16 2008 03:35 AM
Posted 16 September 2008 - 03:35 AM
Posted 16 September 2008 - 09:14 AM
Despite the wonders of modern instrumentation, there are times when you really need to physically "see or feel" a process variable. A gauge hatch on the roof of an atmospheric tank provides you with the means of doing so. They often have a quick opening hatch so you can conveniently open the hatch, drop your measurement device (often a calibrated "stick") into the tank, and quicklu obtain a physical measurement of the tank's level. These hatches could be used for other purposes as well.
Posted 16 September 2008 - 01:25 PM
Say that Hatch (thief hatch) is quite useful when you have a obligation for sampling from the top of oil tank (believe me this is rule in Russia) and when you are also obliged to provide blanketing with inert gas. Stillpipe perforated within tank, with perforation below usual oil level, that asks for oil shipment.
Thief hatch is the quickest way to do this sampling and applicable stillpipe would reduce oil contamination during the sampling.
Posted 28 March 2012 - 11:07 PM
As per API 2000 at point 4.4.2 (ed. 2009), gauge hatch can also act as emergency pressure release if there is abnormal pressure inside the tank.
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
Level Gauge Too Large For Intended UseStarted by Guest_kengor10_* , 10 Dec 2021 |
Inch Of Water Column To Gauge PressureStarted by Guest_james.corrobro@gmail.com_* , 15 Jun 2021 |
Level Transmitters Vs. Level Gauge ReadingsStarted by Guest_Bal_* , 19 Nov 2018 |
How To Read This Gauge?Started by Guest_Alaaeldin55_* , 18 Jul 2018 |
