Dears,
We face problem in continous level measurement in propylene collecting drum. We use DP type (Impluse tube - dry leg calibration)for level measurement. In this case, we observe more pressure acting on LP side,also tried using Capillary type DP - not working. In capillary type once line-up it initially reads as per LG but when tank level changes no change take place in transmitter, same for impluse type LP pressure acts more. For your information - Vapour pressure : operating 15 - 18 bar.Can you give any solution or sugestion highly helpful
regards
pravin
Level Measurement
Started by pravinJayapaul, Oct 14 2008 10:50 AM
Posted 14 October 2008 - 10:50 AM
Posted 15 October 2008 - 08:39 AM
pravin,
Two suspects quickly come to mind if I understand your situation correctly. One is that you are experiencing some sort of pluggage. Is polymerization in your impulse lines a possibility? The second suspect is condensation of vapors and resultant filling of your upper impulse line with liquid. That would not explain a non-responsive instrument however. I suspect that a bit of troubleshooting will reveal the problem. Let us know how it goes and good luck.
Posted 16 October 2008 - 09:34 AM
Gentlemen
Thanks for your reply,as you said we notice condensate on LP which is the reason for more pressure. Now modification we hv done is that put condensate pot on LP filled with glycol and its working now. Firstly, the concern from operations now is will glycol react and quality of product get distrub. Secondly, question comes in my mind now is then why capillary-type LP didnt work out. Also, we didn't face this condensate for past two month from plant startup. More question and observation we face in this topic we can have discuss then n ther when time permits. Once again, thank you for your reply sir.
regards
Pravin
regards
Pravin
![]() Level Control Valve SizingStarted by Guest_rjd452_* , 01 Oct 2022 |
Monitoring Of Level Control In Steam BoilersStarted by Guest_Movers_* , 14 Sep 2022 |
Hydrocarbon Thickness Measurement On ReservoirsStarted by Guest_Bartek_* , 18 May 2022 |
Interface Level In Hysys DynamicsStarted by Guest_CHEMSTRONG_* , 20 Apr 2022 |
