Design data of the compressor is indicated below.
C-10-01 A/B Design
1st Stage 2nd Stage 3rd Stage
Gas Compressed H2 Rich gas
Mol. Wt. 14.76 8.16
Capacity, MMSCFD 9.4 6.55 6.55
Inlet Temp. °F 110 110 110
Inlet Press. PSIA 285 505 1168
Discharge Temp. °F 220 242 230
Discharge Press. PSIA 697 1180 2525
BHP 1306
Power, KWH 974.3
In one of our Hazop reviews, it was identified that Loader valve passing / Malfunction at 1st stage cylinderresults in higher pressure at suction piping of 1st stage. It was propsed to consider installation of Check valve at each cyclinder outlets to avoid back flow and higher pressure at suction piping. Upon review it was identified that, installation of NRV result in higher discharge pressure and might exceed design limit in case of NRV flapper fall situation.
It may be noted that PSV is installed in the first stage discharge piping at the common line (after joining both individual cylinder discharge).
Please review the same and provide your valuable comments regarding the installation of check valve at individual diuscharge.
Feel free to contact for any clarification.
