Dear Sir,
Please explain about Glycol Seal pot exist upstream of Flare .
Somebody says Glycol seal pot present only at onshore Flare setup and not at Offshore Flare setup.Please explain why it is so.
Thanks.
Stu.
Glycol Seal Pot
Started by stu, Nov 20 2008 06:00 AM
Posted 20 November 2008 - 06:00 AM
Posted 20 November 2008 - 06:49 AM
Liquid Seal could be an integral portion of the Flare Package, and used for the following reasons:
1-Flashback protection;
2-Maintain positive header pressure;
3-Direct flare gas flow.
I do not know why it not being used (as you said) in an Offshore Flare.
Posted 24 November 2008 - 09:23 AM
Dear sir,
Thanks for your reply.apart from the function of Liquid head maintaining,shall we use check valve to prevent the back flash of fire flow.
Please clear the doubts.
Thanks,
Stu
Thanks,
Stu
Posted 25 November 2008 - 04:37 AM
QUOTE (stu @ Nov 24 2008, 09:23 AM) <{POST_SNAPBACK}>
Dear sir,
Thanks,
Stu
Thanks,
Stu
Considering check valve closing time lag and possibility of leakage+Main function of check valve as backflow prevention-->No effectiveness could be considered for check valve as preventer of fire's backflash
Posted 29 November 2008 - 01:31 PM
QUOTE (stu @ Nov 24 2008, 05:23 AM) <{POST_SNAPBACK}>
stu,
I would never put a check (non return) valve in a flare header and I have never seen a flare header containing a check valve. Besides the fairly high pressure drop incurred by the use of a check valve, having a mechanical device which could fail (closed) is very unwise in my opinion.
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
![]() Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panoska_* , 23 Feb 2024 |
Gas Seal In Hydrogen Vent StackStarted by Guest_Afshin445_* , 27 Dec 2023 |
Liquid Seal Drum DesignStarted by Guest_maginaga_* , 12 Oct 2023 |
