the oxygenated compounds such as mtbe and tame are how effected to improve the knocking characteristics? and what are the refineries that produce mtbe..to blend it with gasoline?the process implimentation in indian refineries?
Oxygenated Compounds
Started by Guest_ravikumar_*, May 27 2004 06:07 AM
Guest_ravikumar_*
Posted 27 May 2004 - 06:07 AM
Posted 27 May 2004 - 09:24 PM
Ravikumar:
According to the annual Worldwide Refinery Survey for 2002 published by the Oil and Gas Journal in their December 23, 2002 issue:
(1) There were 17 petroleum refineries in India.
(2) Only one refinery (the Hindustan Petroleum Corporation's refinery located at Visakhapatnam) produced oxygenates (i.e., MTBE and/or TAME) and the quantity was 1396 barrels per stream day.
As for how oxygenates improve the anti-knock characteristics of gasoline, you can easily find plenty of material about that by using the Google search engine.
I don't understand your final question about "process implementation in Indian refineries".
I hope this helps you.
Posted 02 June 2004 - 03:18 AM
there are so many oxygenated compounds are used to blend with gasoline,but out of them which one is more econmical and why so?and the present trend of the oxygenated compounds ?the process used in indian refinery(ies) ?
Posted 03 June 2004 - 11:18 PM
Ravikumar:
This is the same question you asked on May 27th and which I partially answered on that same date.
As I said at the end of my response on May 27th, you could probably find quite a bit of information about the oxygenates by using the Google search engine.
Phenolic CompoundsStarted by Guest_Jaldhipatel_* , 17 Feb 2021 |
Adding New Compounds To Aspen PlusStarted by Guest_Vie27_* , 28 Jan 2014 |
Moving Light Compounds To Slops From Blowdown DrumStarted by Guest_Ali_gholamalian_* , 15 Jul 2012 |
Oxygenated Gasoline Such As Mtbe And TameStarted by Guest_ravikumar_* , 27 May 2004 |
