Safety Valve Orifice
#1 bhaskaran
bhaskaran
  • 34 posts
Posted 29 December 2008 - 12:39 AM
In sizing of pressure safety valve ulimately we are finding the orifice area .Orifice area was chosen as per the ASME section VIII guidance( D,E,L,M)
The orifice area for L = 2.853 SQ.Inches & size (in x out) = 3 x 4
dia of orifice from the above orifice area comes to 1.9 inches only (arriving dia from Pi/4*d2 = 2.853 in2)
i have following clarification
i)In safety valve orifice area represents what?
ii)Orifice dia comes only 1.9" whereas inlet safety valve flange size was 3"?
Kindly clarify
Bhaskaran.r
#2 djack77494
djack77494
  • 1,282 posts
Posted 29 December 2008 - 08:48 AM
Bhaskaran,
First let me suggest that you choose more carefully which forum to post questions to. You would likely achieve a better response if this were posted to the relief valve forum where the experts in this sort of matter reside.
Refering to a safety valve orifice area is a bit of a misnomer since a PSV more closely resembles an isentropic nozzle rather than an isenthalpic orifice. Nonetheless, the term is widely used. It represents the minimum cross-sectional flow area available for flluid flow. Since "the orifice" is a restriction internal to the PSV, I don't understand why you are surprised that the orifice diameter is smaller than the flange. It takes some space to put all "the workings" of the PSV inside the valve body.
#3 bhaskaran
bhaskaran
  • 34 posts
Posted 29 December 2008 - 10:05 PM
QUOTE (djack77494 @ Dec 29 2008, 09:48 AM) <{POST_SNAPBACK}>
Bhaskaran,
Thanks jack for your reply.Hereafter i will be careful in putting questions in right forum.Thanx for your advice
