Empower:
First, allow me to explain how we can be of help – accurately, efficiently, and safely:
You MUST be specific in supplying us with all the basic data and scope of work you have in your possession. We can only help if you answer ALL our questions. If we have questions, it isn’t because we are “elaborating”. We are asking questions because you are starving us of basic data while we are trying to be of help. You cannot be selective in what questions you answer or don’t answer. If you don’t feed us data, we can’t be of help - and I personally know I have all the answers you are seeking because I’ve done what you propose many times in the past.
We can’t be guessing at what you mean. We either don’t have the time or can’t take the risk of giving you the wrong advice that could be mis-interpreted and miss-used by you. For example, what does your recent spread sheet mean?This is preliminary selection of compressors numbers, types and capacity We can’t be guessing whether you have broken down your air uses or are telling us something else. What are “carbon handling system” and “Nitrogen System” are these also air requirements?These are name of units(end users). Or are you using Nitrogen as an air substitute? No. Compressed air will be fed to nitrogen generation system for generating nitrogen, as nitrogen generating system(PSA type) requires high pressure air to generate nitrogen. We don’t know.
What are the terms “3 nos” and “2 nos”? They denotes number of equipments. Again, be specific. Realize that no one here has probably any idea of what your job assignment is or what your facilities are like. It is your job to make sure that we have a full, accurate, and detailed description of what is in front of you as a problem.
I asked you: "What do you mean by “CFM”? Please be specific in all details. Is this air flow rate measured at actual conditions (if so, what are these conditions?)?"
You answered: “Yes, at discharge condition with 40 deg. C”. If you are a professional engineer, then you know your response is flawed and lacking in description. No one can identify what you have described because you failed to state ALL the conditions. You left out the PRESSURE of the discharge – so how can we estimate the quantity of air flow handled by the compressors?I agree with u. I have not mentioned discharge pressure, because it is mentioned in my all excel sheet.
Be reasonable and help us help you.
I hope,have understood your requirements and tried to furnish all information.
Pls. let me know, if any more details are needed.
Thanks Art Montemayor once again for your clarifications.Regards,
empower
