Normally, a differential pressure transmitter is installed across any Power Operated Emergency Isolation Valve in liquid service in order to prevent opening the valve against high differential pressure which may cause hydraulic shock and damage the downstream piping.
My subject is:
Is this also required across valve in hydrocarbon gas service?
Dp Transmitter Across Power Operated Isolation Valve
Started by , Jan 18 2009 11:20 AM
Posted 18 January 2009 - 11:20 AM
Posted 18 January 2009 - 12:21 PM
QUOTE (@KMB@ @ Jan 18 2009, 09:20 PM) <{POST_SNAPBACK}>
My subject is:
My subject is:
Sorry@KMB@, Your query is not that clear right now,
Please explain what you exactly require and what is the service perspective or background?
Posted 18 January 2009 - 12:54 PM
QUOTE (@KMB@ @ Jan 18 2009, 12:20 PM) <{POST_SNAPBACK}>
My subject is:
My subject is:
KMB,
Your query is very clear to me.
The answer is:
No it is not required in HC gas service. The reason is:
HC gas is a compressible fluid and there is almost no possibility of hydraulic shock/line packing as observed in liquid service. This has been discussed earlier in the forum and you may want to use the search engine to find about no shock waves generated in gas service.
Hope this helps.
Posted 18 January 2009 - 10:52 PM
My subject is:
My subject is:
KMB,
I would like to make an addition to my earlier reply. If the sole purpose of the DP transmitter is to prevent hydraulic shock in the downstream piping then what I mentioned earlier about DP transmitter not required in HC gas service is correct.
However, while discussing with some of my learned colleagues I found out that the DP transmitter function is more than to prevent hydraulic shock downstream. A high DP across the EI or ESD valve can also cause damage to the valve seat when opened. If this is also to be the criteria for installing a DP transmitter then I stand corrected and there may be a requirement of the DP transmitter even in HC gas service. However, to conclude the requirement of the DP transmitter, a more detailed case-to-case analysis would be required.
Waiting for a feedback from you.
Posted 18 January 2009 - 11:51 PM
QUOTE (Qalander (Chem) @ Jan 18 2009, 01:21 PM) <{POST_SNAPBACK}>
My subject is:
My subject is:
The point is the effect of opening a valve with high DP, in liquid and gas services. Thanks
Posted 19 January 2009 - 12:04 AM
QUOTE (ankur2061 @ Jan 18 2009, 11:52 PM) <{POST_SNAPBACK}>
My subject is:
My subject is:
KMB,
Yes, the concern is the hydraulic shock in the downstream piping. However, I agree with you that avoiding damaging the valve needs to be considered unless the valve is designed to work under this condition. Thanks a lot.
Posted 20 January 2009 - 12:03 AM
QUOTE (@KMB@ @ Jan 19 2009, 10:04 AM) <{POST_SNAPBACK}>
My subject is:
My subject is:
KMB,
Dear @KMB@ Hello,
As indicated in my response to your OP that your query was 'vague/unclear'
Even after all the above discussion by our forum's learned and helping colleague; exact reply to your query was not however possible.
This was the reason to request for
1)Properly phrased query providing maximum needed data/parameters related to any query.
2)Whether it is a set of conditions or appropriate sketch with conditions earmarked on it.
Thus it is re-iterated as many a time mentioned by Art. that initial query must be better/accurately phrased to help the person making query and to help those who put their time and energies to help him/her.
This is not to hurt any body's feeling but a humble proposition to facilitate things better and focused manner.
Best Regards
Qalander
Maintenance And Power ConsumptionStarted by Guest_Lyne_* , 04 May 2024 |
Wafer Check ValveStarted by Guest_Ali4269278331_* , 24 Apr 2024 |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
