So the question reads:
Joe Unidel claims to have invented a steady-state flow device in which the inlet is steam at 300 C and 5 bar, the outlet is saturated steam at 100 C and 1 bar, the device is adiabatic and produces approx. 388 kJ per kg of steam passed through the device. Should be believe this claim?
So this is how I set it up
My Entropy Balance:
dS/dt = 0 = ^S(in) - ^S(out) + 0/T + Sgen
So I obtained ^S(in) and ^S(out) from the steam tables and got the values 7.5499 kJ/kg K and 7.3549 kJ/kg K respectively. I plugged the values in and obtained -.195 kJ/kg K as my Sgen... and since the Sgen cannot be negative, his invented device will not work.
Did I do this correctly?
Also, I feel like i'm missing something since I didn't use the 388 kJ/kg...
Entropy Problem... Just Need My Worked To Be Checked...
Started by tophat22, Jan 21 2009 06:11 PM
No replies to this topic
Posted 21 January 2009 - 06:11 PM
![]() Material Balance ProblemStarted by Guest_vinnay1999_* , 18 Oct 2024 |
Problem With Writing Offshore Plant Design BasisStarted by Guest_Doneisbetterthenperfect_* , 01 Dec 2023 |
Problem With Writing Offshore Plant Design PfdStarted by Guest_Doneisbetterthenperfect_* , 06 Dec 2023 |
Crude Oil Stripping (H2S Conc. Specified In Gas Phase Problem)Started by Guest_nabeelsp1036_* , 16 Jun 2023 |
Aspen Hysys Rankine Cycle ProblemStarted by Guest_ELLEPI_* , 17 Apr 2023 |
