I have to design a system to separate NH3 out of the mixture of NH3 & CO2 in the downstream of a reactor off gas. I have used water scruubing module but that does not work at all and it gives only max 12% Conc. Ammonium carbonate (NH4CO3NH4) as the quantity of NH3 is almost half of the CO2.
I have tried to use the selective membrane for CO2 but that turns out to be very expensive.
Do any one of you have good solution for it. The temperature is of the off gas is around 120 deg C and the pressure of 6 Kg/cm2.
Thanks in advance.
Ammonia Co2 Separation
Started by bhav, Feb 04 2009 07:38 AM
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Ammonia Synthesis Loop SimulationStarted by Guest_Said Salim_* , 05 Apr 2017 |
![]() Ammonia Gas With WaterStarted by Guest_James Clerk Maxwell_* , 09 Sep 2024 |
