Abe Fermentation Product Recovery Methos
17 replies to this topic
#1 gilad
gilad
  • 19 posts
Posted 09 April 2009 - 09:45 PM
I did research on topic of separation of ABE products and found that one of the method used is 3 distillation Columns. In the first one acteone ethanol and water are sent to the top stream, and the butanol sent to the bottom stream. The top stream is sent to a distillation column to separate ethanol and acetone. The butanol stream continues to another distillation column to be separated from water.
I attached a diagram of the process.
I was wondering why not separate the components based on volatility?
First acetone, then ethanol and lastly Butanol.
One reason I can think not to do it is there might be more azetrope mixtures: ethanol-water,butanol-water.
------>harder separation---->more expenisve unit operation to perform the separation----->increase in capital cost.
I would love to hear your inputs on the subject.
#2 riven
riven
  • 178 posts
Posted 10 April 2009 - 03:34 AM
I cannot properly comment as there are not enough details on the feed to the ABE separation column or how pure the authors of the article expect their steams to be specifically around ABE separation column. If you can provide that information we can start discussion.
QUOTE
That is what they are proposing. They propose to remove the volitile components in the ABE separation column leaving the 'heavies'; butanol water.
#3 gilad
gilad
  • 19 posts
Posted 10 April 2009 - 09:17 AM
First of all thanks for you respone.
So far, I have not found the data you requested.
However, lets try starting a discussion based on an hypthetotical case.
Feed is diluted with the following Weight Percent
93% water, butanol 4.6 %, ethanol 0.5%, Acetone 1.9%.
Requirement of Butanol/Acetone/Ethanol products are to be 99.5 percent pure.
[/quote]
I didn't formulate my question right in the first post.
Why not seperate each component at a time instead of two at a time?
#4 riven
riven
  • 178 posts
Posted 12 April 2009 - 07:57 AM
You still need to specify the data I requested. To put it more clearly what is required is the mass balance around the ABE separation column.
You have specified the feed now we need to know the compositions of the outlet streams from this colum i.e. the composition of the feed to the ethanol acetone column and the composition of the feed to the butanol water column.
The reason for not separating each component one by one is due to azeotropes forming, componetns will boil off together. And this is why I want the above data. Ethanol and butanol will form an azeotrope with water as you already specified. Therefore I would expect water to exit the top of the column in the acetone ethanol product stream. This would complicated the final goal to get pure ethanol and pure acetone.
The butanol water separation will require a separation scheme using 2 distillation colums and a phase separator. I will attach some files at a later date.
#5 gilad
gilad
  • 19 posts
Posted 12 April 2009 - 10:24 AM
I am working on simulating the distillation process using ChemCad. I managed to do all the separations using Shortcut column. However, when I tried to change them to regular towers one tower doesn't converge.
Will it help if I attach the chemcad file?
I was leaning toward breaking the azetrope between butanol and water by adding cyclohexane or benzene as entrainer.
I would appreciate if you attach the file regarding the Butanol water separation.
#6 gilad
gilad
  • 19 posts
Posted 12 April 2009 - 08:39 PM
Here is the ChemCad simulation of the distillation process.
#7 riven
riven
  • 178 posts
Posted 13 April 2009 - 04:30 AM
QUOTE (gilad @ Apr 13 2009, 01:39 AM) <{POST_SNAPBACK}>
I do not have chemcad but I will see if I can get it installed.
I would expect that the butanol water tower would not converge, if it is the simulation is probably producing questionable results. I would need to see the simulation however.
In the meantime which column is not converging. And how many colums are you using to simulate the final 3 steps.
#8 gilad
gilad
  • 19 posts
Posted 13 April 2009 - 11:14 AM
Don't bother looking at the Chemcad, since it is not a true represnattion of the situation.
I looked more carefully at the chemcad simulation using towers. I observed that different results are obtained when using tower as oppose to shortcut. I can't think of a reason for that.
Those different results don't allow me to simulate the tower configration using data from the shortcut.
I used only 3 columns.
Thanks for all your help.
QUOTE (riven @ Apr 13 2009, 05:30 AM) <{POST_SNAPBACK}>
#9 riven
riven
  • 178 posts
Posted 14 April 2009 - 01:18 AM
3 towers for the complete train from ABE separator to butanol tower and acetone ethanol tower will not be enough for sure. For the butanol water separation see below: gives a good idea for what is required.
I would expect that a minimum of 1+2 (acetone ethanol water separation) +2 (butanol water) distillation towers to be required. However a single tower may be acceptable if there is not much water in the acetone ethanol tower.
Update having trouble attaching the file will try again later.
#10 Patrician
Patrician
  • 13 posts
Posted 14 April 2009 - 08:14 AM
Greetings and sorry for little offtopic.
What is the efficiency of gas stripping in this process?
Wouldn't it give us highly concentrated azeotrope of ABE and little amount of water?
#11 gilad
gilad
  • 19 posts
Posted 14 April 2009 - 01:50 PM
The bacteria used for the process can produce ABE to a maximum titer of 33 g/L total solvent (water). A higher product concentration will cause product inhibition. By using gas stripping the ABE products are continuously carried out with the gas, so that inhibitory ABE concentration is never reached.
If you want, I can refer you to articles about gas stripping.
You are right, but the goal is to use minimal amount of water.
QUOTE (Patrician @ Apr 14 2009, 09:14 AM) <{POST_SNAPBACK}>
#12 Patrician
Patrician
  • 13 posts
Posted 14 April 2009 - 02:15 PM
QUOTE (gilad @ Apr 14 2009, 02:50 PM) <{POST_SNAPBACK}>
I'll be greateful.
They're using steam or neutral gas?
#13 gilad
gilad
  • 19 posts
Posted 14 April 2009 - 02:30 PM
They are using CO2 and H2 gases produced in the fermenter.
Look at "production of acetone-butanol-etanol from concentrated substrate using clostirduim acetobutycilum in an integrated fermentation-product removal process" by Maddox.
#14 riven
riven
  • 178 posts
Posted 15 April 2009 - 02:18 AM
I have been unsucesssful in attaching the file.
Reference
Control of the Heterogeneous Azeotropic n-Butanol/Water Distillation System
William L. Luyben
Energy Fuels, 2008, 22 (6), pages 4249-4258
DOI: 10.1021/ef8004064 • Publication Date (Web): 19 September 2008
#15 gilad
gilad
  • 19 posts
Posted 18 April 2009 - 05:23 PM
Thanks for the link it was really helpful.
I have one question regarding it if you don't mind.
For the Butanol/water separation with 10 mol% butanol the feed is fed staright to the decanter, whereas for a more diluted feed it is fed to the distillation column and then to a decanter. What is the advantage in feeding staright to the decanter?
#16 riven
riven
  • 178 posts
Posted 19 April 2009 - 05:13 AM
QUOTE (gilad @ Apr 18 2009, 10:23 PM) <{POST_SNAPBACK}>
The feed to the decanter will split into two phases at the higher feed concentration, 10% butanol. This split produces two streams that can be seperated into two pure products.
If we fed directly into a column first, this column would be handling all of the water butanol mixture. It would produce pure water and the resulting azeotrope stream would be fed to a decanter. The size of this azeotrope stream would be more or less the same size as the stream in figure 4. Therefore the resulting decanter and second column would be similar size to that in figure 4. The first coulmn would be larger and require more energy.
#17 drumjeff215
drumjeff215
Posted 22 April 2009 - 02:57 PM
QUOTE (riven @ Apr 13 2009, 10:18 PM) <{POST_SNAPBACK}>
How do you distill the off the acetone and ethanol off from the butanol water? Simulating this setup in ASPEN results in ethanol going into the bottoms with the butanol and only acetone going off the top. My acetone ethanol tower has a lot of water in it.
#18 gilad
gilad
  • 19 posts
Posted 22 April 2009 - 09:12 PM
You are right most of the ethanol goes on the bottom, but it's weight fraction in the bottom stream is quite small (for my case 3.3 %weight). What is your definition of a lot? I get 7 weight percent in the tops.
