Thank You
Ehtylbenzene Hydroxylation/oxidation
Started by , Apr 25 2009 06:23 AM
Posted 25 April 2009 - 06:23 AM
Does anyone have any information on the hydroxylation/oxidation of ethylbenzene?? For example possible products or catalyst used?? What are the pro's and cons of this reaction??
Thank You
Thank You
Posted 27 April 2009 - 02:41 AM
Ethylbenzene oxidation is the first reaction in the PO/SM (or SM/PO) process, designed to produce propylene oxide with styrene as a by-product. There is extensive litterature on this reaction, but I am really not a specialist.
You have some business oriented descriptions of this process in consultant reports (Nextant, SRI), for further details there is for instance a patent by Shell on how this oxidation step is performed. Refer to patent EP 1 932 583 A1
You will certainly find more documentation on internet quite easily.
Hope this helps,
Ollie.
Hope this helps,
Ollie.
Posted 07 May 2009 - 06:36 AM
THANKS ALOT OLLIE
But what is SM & PO?? Do you have any info on the hydroxylation of this compound??
LEANDRA
Posted 07 May 2009 - 11:24 AM
QUOTE (LEANDRA @ May 7 2009, 04:36 PM) <{POST_SNAPBACK}>
THANKS ALOT OLLIE
LEANDRA
LEANDRA
Dear Hello/Good evening,
Although Ollie told this already in a way; I elaborate
'SM' stands for(styrene Monomer) and 'PO'(implies propylene Oxide) Most probaly
'Ollie'Kindly correct if presumed in accuraely by me.
Partial Oxidation ReformingStarted by Guest_KumarChem_* , 05 Dec 2022 |
Partial Oxidation ReformingStarted by Guest_KumarChem_* , 26 Nov 2022 |
Partial Oxidation Of Methanol To FormaldehydeStarted by Guest_Has2riasat_* , 23 Oct 2022 |
Optimization Of Isobutylene Oxidation In A PfrStarted by Guest_dougedouge_* , 10 Mar 2021 |
Technology Supplier For Catalytic Oxidation Of Spent CausticStarted by Guest_cea_* , 26 Mar 2017 |
