Sour Gas Sweetening Using Mdea.
Started by aanita, May 06 2009 01:40 AM
Posted 06 May 2009 - 01:40 AM
Sour gas sweetening using MDEA, can it possible without using continuous dosing of MDEA , where foaming is a great problem?
If possible , under what operating parameters should be adjusted.
Regards.
Posted 06 May 2009 - 11:26 PM
Foaming lead to loss of MDEA at column (you have not mentioned absorption or regeneration column). MDEA dosing (i suppose it is a make-up) is to make up the losses and maintain constant MDEA volume in the loop. Without MDEA make-up will results insufficient of MDEA within the loop and trip on low level.
The issue is foaming and you should target on reduce foaming in the column i.e injecting anti-foam agent.
Posted 07 May 2009 - 03:17 AM
My problem is in absorption column., as regenarator column is less likely to cause foaming.
I want to know without continuous dosing of antifoam, is it possible to run the MDEA based sour gas sweetening plant, if so what precautions should I must take .
Thank you for your time.
Regards.
Regards.
Posted 07 May 2009 - 07:28 AM
Try to use search function in this forum...
Part of those :
i) Foaming In Amine Flash Drum
ii) Frequent Foaming In Absorber
iii) Dipa Foaming Problem In Gas Processing
I have done part of them... You may continue...
Part of those :
![]() How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) BeStarted by Guest_tokotof_* , 29 Nov 2024 |
![]() Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
Mdea QuestionsStarted by Guest_Board operator_* , 09 Jun 2024 |
![]() How To Select Reboiler And Condenser Operating Pressures For A Mdea ReStarted by Guest_Alexis Azamar_* , 27 Mar 2024 |
