Hi dear all experts
I would like to understand how the Stage separator's pressure can be reduced from HP to LP ? Second, is it separator's pressure equal to fluids vapour pressure?
Ethanhan
3 Phase Separator
Started by ethanhan, May 12 2009 08:03 AM
Posted 12 May 2009 - 08:03 AM
Posted 13 May 2009 - 09:08 AM
QUOTE (ethanhan @ May 12 2009, 05:03 AM) <{POST_SNAPBACK}>
Ethanhan,
I assume you are referring to separators as used in oil and gas production. As the fluids leave the reservoir and flow to your first (high pressure) separator, gas is released from the liquids and separated. Water and oil (and sand) also seperate. Typically you are not applying significant heat to the produced fluids, and you are not striving for a liquid-vapor equilibrium situation as you would have, for example, in subsequent distillation processes. It's more a matter of releasing dissolved gases rather than generating vapors. I think this answers your second question, but I'm not sure how to respond to the first. Pressure is controlled by controlling the venting of the gases that are released, and liquids are then "let down" from one separator to the next (lower pressure) separator under level control.
Posted 17 May 2009 - 05:30 AM
Djack77494
Thanks for your reply. However, how to set the operating pressure at LP or HP? Any consideration? how to get know whether it is equilibrium state?
Posted 18 May 2009 - 07:49 AM
A major factor in all this will be consideration of the gas compressor(s). Certainly, you could set the pressures at any level you'd like. But you want levels that make sense when it comes to the compressor. Very simplistically, let's say your final stage of dewatering is at 1.5 bar[A], and that you aim for having a compression ratio of 3. So your low pressure seperator would operate at a bit over (3*1.5) = 4.5 bar[A]. Similarly, the high pressure separator would operate (3*4.5) = 13.5 bar[A]. Of course this is an extremely simplified example, and other considerations come into play.
I'm not sure what you mean about equilibrium. In general, you would have one equilibrium stage for each separator.
![]() Separator CarryoverStarted by Guest_R_Gowtham_* , 18 May 2022 |
Three Phase Seperator ModificationStarted by Guest_halkeshhulk_* , 10 Jun 2025 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
