Hello
Can anybody help me predicting the travel of a control valve knowing that the following data are available:
1- Flow condition: flow rate, pressure drop of the system & pressure drop of the control valve.
2- Valve flow characteristics & Rated CV.
Can the inherent flow characteristics chart be used to determine the lift ? explanations are welcome.
Valve Travel (%lift) Calculation
Started by MFAHOS, May 18 2009 07:43 AM
Posted 18 May 2009 - 07:43 AM
Posted 18 May 2009 - 01:39 PM
When you say that you know the valve flow characteristics and the valve's rated Cv, I take that to mean that you know the relationship between the Cv and the %lift. So if the valve's Cv is say 25, at its full open position, then you would know that to get the valve's Cv to 12.5 you might need a lift of about 80% if you had a valve with equal percentage characteristics, a lift of 50% with a linear valve, and a lift of just over 25% with a quick opening valve. (For a specific family of valves, these values would vary somewhat.) Typically, you might have a plot of %Maximum Cv vs. %Lift.
You know the relationship between flowrate and the control valve's Cv - by definition Cv is the capacity in gpm of 60 degreeF water that will through a valve with a 1 psi pressure drop. So our fully open valve will pass 25 gpm of water with a 1 psi dP. When its Cv is halved, for example with 80%Lift and an equal percentage valve, it will pass 12.5 gpm. If fully open and the valve's pressure drop is raised to 4 psi, then it will pass 50 gpm because the dP vs. flowrate relationship is of the square root of dP. I hope this offers you a bit of explanation about the operation of a control valve. It's hard to put some of this in words, so I'd suggest you follow up with some suitable vendor's literature such as the Control Valve Handbook from Fisher/Emerson. Lacking contact with valve vendors, you could try a textbook or the internet.
Posted 18 May 2009 - 11:37 PM
QUOTE (MFAHOS @ May 18 2009, 08:43 AM) <{POST_SNAPBACK}>
Hello
Assuming you are using globle type control valve with equal percentage trim characteristic, below is the equation you can use
L = 100*[1+ln(CV/CVmax)/lnR]
where L= %opening of valve
R= rangeability (ratio of max controllable flow to min. controlable flow)
Cvmax = valve selected Cv
For linear opening, it is the simple ratio of Cv at desired flow to valve selected Cv
good luck...
Posted 20 May 2009 - 08:01 AM
Thanks djack & Jiten for the fast reply. your information was very helpful.
Then to estimate the lift, all we have to do is to calculate the ratio CV/CVmax and use the chart shown in the figure (Assuming that the Horizontal axis is for lift and the vertical for CV ratio).
Thanks.
Thanks.
Posted 20 May 2009 - 04:51 PM
Looks like you've got it. Good luck.
Posted 20 May 2009 - 10:12 PM
QUOTE (MFAHOS @ May 20 2009, 09:01 AM) <{POST_SNAPBACK}>
Thanks.
Thanks.
GR8....but just one thing keep in mind that thse graph is assuming inherent characterstics but practically it is not.
good luck...
The Basis Of Calculation To 3% Pressure Loss At The Inlet Of PressureStarted by Guest_phoenixmoca_* , 14 Mar 2026 |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
