What are the environmental considerations taken in cooling tower desing and operations?
Cooling Tower
Started by Guest_Donatius_*, Aug 18 2004 06:49 AM
#1 Guest_Donatius_*
Posted 18 August 2004 - 06:49 AM
Posted 18 August 2004 - 12:40 PM
Donatius:
Two of the environmental cosiderations in the design and operation of an evaporative cooling water system are:
(1) Maintain a blowdown rate that is as low as possible (which means operating at concentration cycles as high as possible).
(2) Install drift eliminators to minimize the drift loss of water to the atmosphere.
The purpose of the two items above is to minimize the use of fresh water as well as, in some cases. to reduce the corrosion on nearby parked cars, etc. caused by the deposition of cooling tower drift losses.
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
Minimum Tower DiameterStarted by Guest_AnbIran_* , 17 Nov 2023 |
Sizing Of Cooling Water Pipe LineStarted by Guest_Asif Azeez_* , 08 Jan 2021 |
Heating And Cooling Circuit DesignStarted by Guest_AAZIZ_* , 20 Jan 2024 |
How To Calculate Cooling Rate Of CrystallizerStarted by Guest_snehchem_* , 04 Jan 2024 |
