I'm looking for management ideas in regards to disposing of spent amine charcoal and amine sock filters (petroleum refining). We've had a couple of waste bins catch fire due to the spent charcoal. We've also had spent filter media catch fire upon disposal.
How are others managing / disposing of these items?
Thank you.
Managing Amine Charcoal And Filters
Started by Guest_bird33_1967_*, Jun 16 2009 12:24 PM
Guest_bird33_1967_*
Posted 16 June 2009 - 12:24 PM
Posted 21 June 2009 - 10:14 AM
I guess if you just keep them wet all the time - till the final disposal - the ignition will not occur.
For waste management try to explore the regulations of that particular country where you at, and/or to look for experiences in similar plants.
Posted 07 August 2009 - 01:56 PM
What is the process? I am very familiar with amines in refineries and have never seen this. I would ask your carbon supplier to do a thorough analyses of the spent material to determine why it is bursting into flames. I would review the change out procedures to see if the vessel is being purged properly prior to dumping.
Posted 11 August 2009 - 02:40 AM
QUOTE (Zauberberg @ Jun 21 2009, 08:14 PM) <{POST_SNAPBACK}>
Matter seems to me of
contamination with some pyrophoric materials (Zuberberg's keeping water wet guidance is pertinent)
either produced during the reactions un-noticeablely
or finding their way (from some other upstream sources) into the charcoal bed
Another possibility is that CS2(Carbon Disulphide generation and retention in the bed)
Since all the Pyrophoric materials are susceptible to very slow un-noticed oxidation in ambient air contact at temperatures as low as around 54 Celsius.
Useful Details are available on this very website www.cheresources.com
![]() Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
Dp Drop In Structured Packing Amine Absorber Causing IssuesStarted by Guest_kek12345_* , 10 May 2024 |
Back Pressure In FiltersStarted by Guest_panoska_* , 22 Jan 2024 |
![]() Amine System FiltrationStarted by Guest_Hanaa_* , 09 Jan 2022 |
Rich Amine Quality In Lpg Absorber TowerStarted by Guest_Alchemes_* , 21 Nov 2022 |
