we starat put aplan to inspect all STEEL STRUCTURES (vessel suport ,pipe rack,and all supports)
so the code for s.s awsd1.1 and iso 1721-1-2
put these for erected welding not for inspection
we use the API RECOMENDATION AND INSPECTION LIKE API 574 ,570,
BUT CAN ANY ONE PROVIDE US WITH THE CODE FOR S.S INSPECTION
Steel Structures
Started by YEHIA, Jun 18 2009 02:03 AM
Posted 18 June 2009 - 02:03 AM
Posted 19 December 2009 - 02:30 PM
.. put a plan to inspect all STEEL STRUCTURES (vessel suport ,pipe rack,and all supports)
I have not seen vessel supports, pipe racks, etc of stainless steel (SS), evidently because of their high cost.
Thames river bridges are Carbon steel (CS), protected from corrosion through proper paints.
So be sure structures under inspection concern SS and not a special grade of CS.
Nevertheless industrial SS structures are not impossible. Just some hints that might be useful or not:
http://www.euro-inox...htm/p_4_EN.html (needs some patience)
EN 10088-1 : 2005 refers to concrete armored through SS
Of course these refer to European standards. If you want US standards, you have to search for corresponding US codes after you have located the European ones.
Sorry not to be able to be specific
Edited by kkala, 19 December 2009 - 02:37 PM.
Max Wall Temperature Stainless SteelStarted by Guest_ChristianColombini_* , 23 May 2024 |
Cost Factor/index Table For Mocs Like Carbon Steel, Glass Etc.Started by Guest_daraj_* , 29 Aug 2021 |
Spark Potential Stainless SteelStarted by Guest_kangas_* , 03 Jun 2021 |
Equation For Heat Loss Through Carbon Steel PipeStarted by Guest_Process EngrPsh_* , 11 Dec 2019 |
Stainless Steel 304 / 304L 18/8 For Cryogenic.Started by Guest_Mairon_* , 27 Jan 2019 |
