Thermowell Failure
#1 Jags
Jags
Posted 26 June 2009 - 07:20 AM
Good Day,
I have attached some pictures of a failed thermowell on one of our Ammonia Plants. From your knowledge on thermowells, are you able to suggest what may cause it to fail like this?
Material of thermowell – Kanthal
Operating Temperature – 1850F
Mass Flow Rate – 600-650 klbs/hr
Velocity – 100 ft/s
Density – 0.3659 lb/ft^3
Pressure – 550 psig
#2 Whit123
Whit123
  • 27 posts
Posted 27 June 2009 - 11:06 PM
QUOTE (Jags @ Jun 26 2009, 07:20 AM) <{POST_SNAPBACK}>
Good Day,
Velocity – 100 ft/s
Pressure – 550 psig
Apparently from the pictures it appears that under the process conditions, the material of the thermowell has become soft and malleable (perhaps even melted). What is the MOC of the process vessel/pipe in which this is used? Can the same MOC be an option? Have you tried Ceramic material thermowells?
If Kanthal is not supposed to behave like this under the process conditions that you have specified then it may be either that
1) The MOC is NOT Kanthal, perhaps you should get it tested from a lab?
2) The Process conditions have deviated substantially due to a process upset?
#3 riven
riven
  • 178 posts
Posted 01 July 2009 - 07:15 AM
Can you give an indication of how much of the thermowell was inside the process stream?
For example if nearly all of the thermowell was inside the stream there is no reason why the deformation would not be seen along the entire length.
To me the damage initially looks like a deformation caused by mechnacial stress of some sort i.e. incorrect removal of the thermowell.
#4 davebartran
davebartran
  • 9 posts
Posted 09 July 2009 - 10:28 AM
piece of cake, but there are several factors involved:
[1.] pressure collapse of the protection tube
[2.] materials of construction (Kanthal good for furnce environment but not your service)
[3.] a secondary isssue is that at 100 ft/s you are going to see the well just fold over
there are engineered solutions
Dave
Velocity – 100 ft/s
Pressure – 550 psig
[/quote]
