Standard Orifice Size Of Breather Valves
#1 kpavan
kpavan
  • 35 posts
Posted 25 August 2009 - 11:21 PM
Hi all,
Can anyone tell me the standard orifice sizes for breather relief valves?
Thanks in advance,
Pavan
#2 latexman
  • 1,893 posts
Posted 26 August 2009 - 07:47 AM
Your question is somewhat confusing because you have combined the traditional names of two separate relief devices into one. You combined breather vent and pressure relief valve and I'm not sure what you want. Breather vent units do not come in "standard orifice sizes" like pressure relief valves, so you are probably asking about those.
Have you used the Search or Advanced Search functions of the site to see if your question has already been answered?
#3 proinwv
proinwv
  • 391 posts
Posted 26 August 2009 - 08:17 AM
Pavan, Latexman is correct.
Having said that, look to the manufacturers catalogs. They will also have flow curves which are helpful.
#4 CMA010
CMA010
  • 92 posts
Posted 26 August 2009 - 02:46 PM
In some parts of the world the term breather valve is an often used synonym for conservation vent.
#5 kpavan
kpavan
  • 35 posts
Posted 27 August 2009 - 12:29 AM
Thanks to all of you for reply.
Sorry for the confusion, as rightly said by CMA010 we use the term breather valve instead of breather vent and breather valve is a vacuum/pressure relief valve, so i used the term like that.
Latexman,
You are right, my main question is "Does Breather valves have standard relief orifice sizes like pressure relief valve". I have searched/checked the forum, and API-2000,560...but i didn't find the answer. But what/where ever i have searched, i have got the sizes like 2", 3",... and 2"x3", 3"x4" .... and so on. So i am little curious to know whether any standard orifice sizes for breather valves are there or not.
Paul,
I am going through the curves.
