Desuperheater
Posted 29 August 2009 - 01:28 AM
In an application for heating slurry the dry saturated steam from Boiler has been used with STHE. The pressure is reduced with PRS from 10 kg/cm2 to 3 kg/cm2,I would like know the need of using the desuperheater for this system.As, I understand the desuperheater is mainly used for superheated steam but as we reduce the pressure there may be a need of taking superheat from steam even for dry saturated steam. I discussed with many people and they are recommending not to use desuperheater.
Kindly comment on the above topic. I would like to know the reason for having or not having desuperheater for this application.
Thanks,
ASB
Posted 29 August 2009 - 12:14 PM
Dear all,
Thanks,
ASB
I am not entirely sure on your application, but if there is a chance of the cooler fluid polymerizing or other temperature related fouling then a desuperheater will be used to help reduce the wall temperature in the exchanger. Bear in mind that with a desuperheater you will still remain within say 20F of the actual steam dew point.
Posted 01 September 2009 - 09:31 AM
Minimum Distance Between An Attemperatorkum/desuperheater And A SteamStarted by Guest_muthukmaar_* , 27 Apr 2020 |
Desuperheater SizingStarted by Guest_farid.k_* , 11 Apr 2018 |
Trouble Shooting DesuperheaterStarted by Guest_Pingue2008_* , 09 Dec 2014 |
Attemperator / Desuperheater For HrsgStarted by Guest_Boeid_* , 13 Jun 2012 |
![]() Desuperheater PsvStarted by Guest_vibhs_* , 21 Sep 2011 |
