Flash Drums Uses
#1 Dudee
Dudee
  • 7 posts
Posted 02 November 2009 - 09:38 AM
Hi all,
I have a question: Is it always needed to install a flash drum separator after a partial condensation? if not, in which cases is it applied?
Any help is welcome. Thanks.
#2 shan
shan
  • 692 posts
Posted 02 November 2009 - 03:48 PM
Hi all,
The question is why you want to condense the stream. If you want or don’t want gas/liquid, you have to install a separator to obtain or get rid of the phase desired/undesired. If your purpose is to lower the stream temperature, you do not need a separator. For example, there is no separator needed, if you want to lower a stream temperature to less than 120 F for avoiding personal protection insulation downstream.
#3 Dudee
Dudee
  • 7 posts
Posted 07 November 2009 - 02:39 AM
Hi all,
Sorry if I wasn't clear: I do want to separate the gas/liquid streams, what I don't konow is if I can make it just with the heat exchanger (shell and tube) or if I need the flash drum... It's a general question , just to know.
#4 djack77494
djack77494
  • 1,282 posts
Posted 12 November 2009 - 10:11 AM
Dudee,
To achieve effective separation of the liquid and vapor phases, you will need to design you equipment for that. The normal practice is to have some sort of flash vessel, often called an accumulator or a reflux drum, downstream of a partial condenser. Is one absolutely required? NO! You could design the exchanger to achieve the separation. For example, kettle type exchangers do just that. But that is not the normal practice for the situation you describe. And, my opinion in all such matters is that if you don't have a good reason to change that which has been used successfully in the past, don't change it. Would you like a long career?
Edited by djack77494, 12 November 2009 - 10:12 AM.
