Flow Compensation Formula
#1 chemtan
chemtan
  • 60 posts
Posted 16 December 2009 - 12:21 AM
What is the formula to calculate compensated flow for a DP Type transmitter.
I know of one formula that we commonly use for flow across orifice:
Flow = Flow Constant (K) x SQRT [(Differential Pressure x Inlet Pressure in abs.)/ (Sp.Gr x Abs. Temp)] --- (A)
But the construction team on site sent me below formula that calculates "Actual Quality velocity" - new word for me.
Actual Quality velocity = Density x DP across orifice x SQRT [(Design Temp./Actual pressure (abs)) x (Actual abs. Pressure/Design Pressure)] --- (B )
Help require is:
1- What does "Actual Quality Velocity" stands for??
2- How are DP type transmitters calibrated for "compensated flow" in field??
Edited by chemtan, 16 December 2009 - 12:22 AM.
#2 chemtan
chemtan
  • 60 posts
Posted 16 December 2009 - 02:11 AM
Below are the process conditions for measurement:
Operating Temp, Deg C :
Min/Max/Design: 17 / 60 / 160
Operating Pressure, KPA :
Min/Max/Design: 4813 / 5124 / 6895
Flow rate, Kg/hr :
Min/Max: 74640 / 22,4950
Edited by chemtan, 16 December 2009 - 02:11 AM.
