Heat Loss Calculation For A Bare Pipeline
Posted 04 January 2010 - 03:52 PM
Can anyone teach me how to calculate the heat loss for a bare stainless steel pipe? I want to know the temperature change along the pippe length in order to decide if I need insulate the pipe. The water tmeperature inside the pipe is 25 degC, windspeed is 5m/s. Ambient temperature is 10 degC. The lowest accepted temperature of water is 16 degC, I know the farthest destination the pipe needs to go, not sure if the temperature is still higher than 16 degC after travelling.
Thanks and Regards,
Blue
Posted 05 January 2010 - 01:09 AM
Sorry to tell you that nobody will teach you , you need to find ressources like "process heat transfer " from Kern or Perry's chemical engineers' handbook or free book from internet J.H lienard "heat transfer".
Then you can use this software :http://www.cheresources.com/inssoftwarezz.shtml
Hope it helps you Breizh
Posted 05 January 2010 - 01:32 AM
Dear all,
Thanks and Regards,
Blue
Take a look at this link:
http://www.cheresour...__1
Additionally also look at this link:
Edited by ankur2061, 05 January 2010 - 01:48 AM.
