Reactor Product
Started by Guest_Guest_*, Dec 16 2004 07:27 PM
Guest_Guest_*
Posted 16 December 2004 - 07:27 PM
Can the product stream coming out of a reactor be described as 'the reactor effluent' ? Or is that technically incorrect ?
Posted 17 December 2004 - 12:17 AM
'Effluent' in chemical engineering often refers to discharged liquors, whereas civil engineering defines it as liquid waste of sewage and industrial processing. Having worked in a water treatment plant myself, effluent simply is the final treated water which in this case was my product. If you're talking about closed reactors in a continuous process, the product stream is the effluent. Just make sure you don't use it for batch processes. Good luck.
Posted 17 December 2004 - 03:56 AM
Petroleum refineries generally have a good many reactors. In that industry, it is quite common usage to call a reactor's outlet stream the "reactor effluent".
Steam Flow And Heating Time In Batch ReactorStarted by Guest_seagal6_* , 16 Jul 2025 |
Multi-Tubular Packed Bed ReactorStarted by Guest_shambola_* , 12 Feb 2025 |
Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
Secondary Heating Loop For ReactorStarted by Guest_TheChemEng_* , 28 Nov 2024 |
Need Help For Utility Flow Rate Calculation For A Chemical ReactorStarted by Guest_Asisr_* , 12 Sep 2024 |
