I have the data for packed column for SO3 absorption in the H2SO4 plant (absorption with reaction) and I need to calculate the height of packed in a new column. The concentration of SO3, volume flow rate of gas and liquid, packing type and column diameter will be different for the new column. Is there a easy way to calculate the new packing height, without using the mass transfer rate equations??
Thank you in advance for helping me.
Packed Columns Dimensions
Started by marecki, Jan 10 2010 10:44 AM
Posted 10 January 2010 - 10:44 AM
Posted 10 January 2010 - 10:49 AM
And how do you think to do that without mass transfer calculation/simulation?
Posted 10 January 2010 - 11:07 AM
I was thinking about dimensional analysis, the value of all parameters will be in the same order of magnitude (+/-20%).
Posted 10 January 2010 - 11:47 AM
There is different concentration of SO3, different volumetric flow of gas and liquid phase, different packing characteristics. No pro-rating calculations are possible, in my opinion.
Posted 10 January 2010 - 12:08 PM
Thank you for your advices I will perform the mass transfer calculation to solve this problem.
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
![]() Multi-Tubular Packed Bed ReactorStarted by Guest_shambola_* , 12 Feb 2025 |
Choice Of Model To Packed Bed ReactorStarted by Guest_Kakashi-01_* , 06 Dec 2023 |
![]() Reducing Steam Consumption In Vacuum Packed DistillationStarted by Guest_dpunnn_* , 30 Nov 2023 |
