hi to all,
can anyone give some idea on what basis filter area of agitated nutsche filter dryer is selected?
Filter Area For Agitated Nutsche Filter Dryer
Started by Anil Panchal, Feb 16 2010 03:25 AM
Posted 16 February 2010 - 03:25 AM
Posted 16 February 2010 - 01:07 PM
hi to all,
Anil,
I believe Agitated Nutsche filter dryer are speciality designs of the standard gravity or vacuum nutsche filter dryer for filtration & drying in dye, paint & pharmaceutical industries. I don't think you might find much open literature on the design and filtration area of such speciality equipment. Only manufacturers of the equipment would know the design aspects of such an equipment. There may be empirical correlations involved in sizing of the filter with lot of information required in the form of inputs such as material to be filtered, filtration efficiency, cake formation rate, concentration of solids in the influent etc.
Why don't you consult some reputed manufacturers for your specific requirement? You can float an enquiry to some manufacturers/vendors based on your requirement & I am sure they would give you some ball park figures for you to make a decision for selection of such an equipment considering the fact that most manufacturers would like to build a relationship with prospective customers without divulging too much proprietary information.
In case my understanding of you being a prospective buyer of this equipment is not correct & you are actually trying to design an agitated nutsche filter dryer then I am sorry I cannot help you.
Posted 03 November 2011 - 12:59 AM
Hi Ankur.
I am looking for expert of ANF machine, I design a small machine for test,but I think that have some problems for it .so Pls teach me for some key point of design ANF.tks ,I attached the drawing of ANF.
![]() Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
![]() Ways To Reduce Wetted Surface Area In Psv SizingStarted by Guest_KoreaGyu_* , 21 Aug 2024 |
![]() ![]() Carbon Bed Filter CalculationsStarted by Guest_kyayura_* , 25 Jul 2023 |
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
