I would like to know the vapor pressure of water (ice) at temperatures of -25 C and -50 C. I am having a difficult time finding them.
Thank you so much for your time.
Vapor Pressure Of Water
Started by , May 16 2008 09:38 AM
Posted 16 May 2008 - 09:38 AM
Posted 16 May 2008 - 09:46 AM
ckarni:
You've come to the right place for the information. Next time use our "Search" feature. I've answered this same question so many times, I've lost count.
Go to:
and get your answer.
Go to:
http://webbook.nist.gov/chemistry/fluid/
Posted 16 May 2008 - 10:18 AM
Thank you for your quick reply, but this website does not allow temperatures below 273.15 K (unless I am mistaken), and that is exactly what I need. Do you or anyone else have any suggestions?
Thank you.
Thank you.
Posted 16 May 2008 - 12:55 PM
You're right! I didn't check the limits on the database. But I quickly went to Google and found a bunch of other sources, some of which are:
http://www.its.calte...als/ice/ice.htm
http://www.lsbu.ac.u...er/strange.html
Why didn't you also "Google"?
Design Compressor For 35% H2S & 1.05Ksca Suction PressureStarted by Guest_GanjiS_* , 29 Apr 2024 |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
