Hello everyone
Is there a way to predict the amount of MeOH to be injected as a function of natural gas flow and water content, in order to inhibit hydrate formation ? In other topics i saw that once formed, hydrate will not dissolve upon MeOH injection, is this right?
Hydrate Inhibition With Methanol
Started by Purpurato, Aug 13 2012 10:49 AM
hydrate methanol amount inhibition
Posted 13 August 2012 - 10:49 AM
Posted 13 August 2012 - 12:32 PM
Purpurato,
Use the search feature of the forum and you will find several posts on hydrate formation and hydrate inhibition. One link is provided below:
http://www.cheresour...ate-inhibition/
Posted 18 August 2012 - 06:09 AM
an accurate correlation to predict the inhibition effect of methanol is that of Nielsen and Bucklin
dT = -129.6 * LN (1.0 - XMeOH)
dT = degrees Fahrenheit
XMeOH = 0 ... 0.8
you can calculate the hydrate formation temperature (at specified pressure) with and without methanol injection with many software applications, as example I use Prode Properties (see prode.com).
XMeOH = 0 ... 0.8
![]() Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
Variables That Affect Energy Consumption Of Methanol PlantStarted by Guest_mobody_* , 15 May 2024 |
Methanol ProductionStarted by Guest_Manue_* , 21 Mar 2024 |
Let Down Vessel In Methanol ProcessStarted by Guest_Manue_* , 21 Mar 2024 |
