Dear all,
I'm dealing with an overhead pressure control scheme (defined by others) for a debutanizer column that comprises: upstream valve to the air condenser, hot-vapor bypass and air flow rate manipulation, with a drained condenser, not flooded, as per the basic engineering. The vapor valve upstream the condenser regulates column pressure and the vapor by-pass controls pressure in the reflux drum.
I’ve read some literature and articles, and I could found the following:
- Drained condenser by-pass alone, is not recommended by Kister (Distillation Operation, page 539) because “it may not work” according to cited literature.
- Proposed scheme is recommended by Shinskey (Distillation Control), according to paper “Quantitative Comparison of Alternative Control Schemes for air-cooled condensers”, by W.L. Luyben. I don’t have the Shinskey’s book to further analysis, BUT in the paper always is assumed a subcooled reflux, so the condenser is partially flooded or not drained. This two valve combination has some advantages, and disadvantages.
I understand how this system works with subcooled reflux, but I have doubts about how functions with a drained condenser.
My assumption about how this scheme works (with drained condenser) is that if the accumulator pressure increase (because air temperature surge) the hot-vapor bypass will tend to close and fan speed will rise. In the opposite, if accumulator pressure decreases, vapors from tower top will pressurize the vessel, through opening hot-vapor by-pass valve.
My question is: do you think my assumption is correct? What is your opinion about to install this scheme without a partially flooded condenser?
Thanks a lot.
Edited by HLO, 12 March 2013 - 05:05 PM.
