I am doing some calcuations for depressurizing of Stablizer ovhd system. Please refer attached PFD for reference. Depressurizing valve is located on stabilizer ovh column along with PSV which is designed for fire case. Based on my understanding during fire stabilzer reboiler would be affected causing rise in temperature further vaporizing liquid in bottom which will result in high pressure in column and to protect this we already have PSV in overhead line but as fire continues and PSV is pop-out we need to depressure the system to 100psi in 15 mins as per API 521.
In Stablizer ovhd condenser around 97% vapor is getting condensed (normal operation).
My concern is tube side being sea water and since it doesnt have any automatic valve can we take credit of sea water not being blocked in case of fire contingency and most of the vapors are getting condense.
Can we just consider only stablizer ovh receiver liquid volume for depressurization calculations and size our valve based on receiver volume alone?
Hoping a positive guidance on this problem from our experts.
