I have a question regarding the design of a 2-Phase separator for a well-site. The separator needs to be designed to handle: 240 bbl/d oil (API gravity 38), 1847 bbl/d water, and 0.338 MMSCFD gas. I've never had to size a separator with that high of a water to oil ratio. I'm not sure what the liquid retention time should be, the only design rule pertains to the API gravity of the oil and not the amount of water.
Would the following rule still apply given the high flow rate of water (From API 12j)?
Gravity >35, 1 min retention time
Gravity 20-35, 1-2 mins retention time
Gravity 10-20, 2-4 mins retention time
Thanks for your time.
