i have a problem finding the source of this equation and coefficients as seen in the pdf file in order to calculate the corrected flow of the gasoline stream would you please help me out regarding the sources
Question About Flow Corrections For Gasoline
Started by koko, Feb 20 2015 10:10 AM
Posted 20 February 2015 - 10:10 AM
Posted 28 February 2015 - 10:10 AM
no one ????
Posted 28 February 2015 - 05:53 PM
Dear Koko,
You must employ the equation of Api mpms 11.1, if you don't have the exact reference.
Somebody can do a regression and obtain a equation, but it is important to know the validity range. In the api mpms 11.1 it is clear.
Also, I can't find the second equation of your reference, then maybe of dangerous to employ this equation without backless.
NAPO.
NAPO.
Epc Basic QuestionStarted by Guest_poojabathula369@gmail.com_* , 24 Apr 2024 |
Overpressure Scenario QuestionStarted by Guest_panagiotis_* , 08 Mar 2024 |
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
