Drying by hot nitrogen should be done after hydro-test for chillers of the refregerent system, but in my company using hot nitrogen is not available so, is it ok for using hot fuel gas instead of hot nitrogen for drying the chillers?
thanks
Posted 21 March 2015 - 02:08 PM
thanks
Posted 21 March 2015 - 02:22 PM
shady,
You can use hot air rather than hot nitrogen; but it can't allow the dew point to achieve up to very low temperature, say around -60 C,...
Posted 21 March 2015 - 02:48 PM
The problem of using (dry) fuel gas is not in effectiveness of drying, but rather in disposing of wet gas.
A common drying procedure involves continuous sweeping of dry gas (N2) through predefined loops/sections of the plant, normally between two isolation points. During this process, convenient vent and drain connections are kept open, to enable elimination of liquid water and wet Nitrogen from the system. Now if you imagine hydrocarbon gas employed in this operation, you may end up with vapor clouds inside and outside of the facility. Depending on composition of the fuel gas, ignitable (and possibly toxic) vapor clouds may be formed and, if there are other operating areas around, this can create significant and perhaps intolerable hazard.
We don't know any details of your drying procedure, layout of the plant(s), fuel gas parameters, and details of the equipment/piping. It is virtually impossible to provide you with straight "yes" or "no" answer, except to point at the hazards mentioned above. As suggested by Fallah, I'd prefer using other medium (air) if it is available. A typical dew point of Instrument Air is more than low enough to provide complete drying.
Posted 21 March 2015 - 03:15 PM
dear fallah & Zauberberg
first thanks for your reply,
for the point of draining or venting the drying gas, it will be directed to the flare so it will not make a hazard problem.
Also i thought about using fuel gas as a drying gas as it will be used for drying and oxygen freeing at the same time so it will reduce time.
According to the unit manual, drying is done by instrument air (as fallah says) and then displacement is done by normal fuel gas.
Posted 21 March 2015 - 03:19 PM
If you have all the drain and vent connections piped to closed systems (closed drain and flare), you are ready to go.
Posted 21 March 2015 - 03:21 PM
so you suggest that this is a good way for effeciency and saving time?
Posted 21 March 2015 - 03:40 PM
Posted 21 March 2015 - 03:46 PM
shady,
Why not to do as per unit manual, i.e. drying with hot instrument air and then replacing the air with fuel gas?
Posted 21 March 2015 - 03:50 PM
thanks Zauberberg, fallah
dear fallah
In the unit manual drying is done by normal temperature instrument air not hot instrument air, also fuel gas in my plant enters a drier first before using and it is easy to use it in hot situation.
I suggested that technique for saving time and to be sure that drying is done perfectly by the hot gas.
Posted 21 March 2015 - 04:04 PM
shady,
The dew point of the instrument air in your plant is certainly so low such that has adequate capability for drying out in normal temperature, then probably no need to be hot when drying operation getting started...
Posted 21 March 2015 - 04:15 PM
so it is better to do as manual
Posted 21 March 2015 - 04:22 PM
shady,
I think so, because unit manual has likely been written based on the relevant site conditions, available facilities and economical/safety standpoints...
Posted 21 March 2015 - 10:02 PM
Something doesn't seem right about purging air with fuel gas in a closed system. Sounds a bit hazardous to me. Is it your plant practice to purge air from equipment using fuel gas?
Posted 22 March 2015 - 12:08 AM
Agreed with Bobby...in fact, if the drying gas (air) venting and subsequent fuel gas for purging is directed to flare sounds the condirions to be a bit hazardous...
Posted 22 March 2015 - 03:03 AM
Purging of air is - according to Dave Simpson (MuleShoe Engineering, and one of the top contributors at Eng-Tips forums) - one of the most hazardous operations in oil and gas production. He had posted an excellent working manual on removing air from process equipment and piping which I am uploading in this thread.
For those who like extended reading on the subject, AGA has developed a document titled "Purging Principles and Practice" which is a legally binding document in the US and can be accessed here: https://law.resource...urging.2001.pdf
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , Today, 08:17 AM |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
