Design Pressure Of Atmospheric Tank
#1 Ibnu84
Ibnu84
  • 20 posts
Posted 18 June 2015 - 11:12 AM
Hello All,
What is the design pressure of atmospheric tank. Does it include static head?
I have an open drain tank with a vent routed to atmosphere 3 m above the tank. Unfortunately it does not have overflow line. Thus the tank is designed full of water up to the top of vent line.The tank height is 3 m, so that pressure at tank bottom equals to 0.6 barg. Does it mean the tank design pressure is 0.6
PED will be applicable for tank with PS (design pressure) more than 0.5 barg. In my case, is PED applicable?
Edited by Ibnu84, 18 June 2015 - 11:16 AM.
#2 fallah
  • 4,955 posts
Posted 18 June 2015 - 12:29 PM
Ibnu84,
The atmospheric tanks aren't designed to be full of water up to the top of vent line at all. Then mentioned tank can be full of water only up to 3 m height; but nonetheless the tank's design pressure depending on the roof weight is a few mbarg...
#3 shan
shan
  • 692 posts
Posted 18 June 2015 - 01:22 PM
API 650.  3.1.2 design pressure: The maximum positive gauge pressure permissible at the top of a tank when the tank is in operation.
It does nothing with the level of tank liquid.
#4 latexman
  • 1,690 posts
Posted 18 June 2015 - 02:49 PM
Just do NOT specify the design pressure as "atmospheric pressure"!  Even with an open vent there will be backpressure during credible scenario flows.  Be conservative.  Give some cushion (safety factor).
Old tanks that were specified as "atmospheric pressure" have caused me all sorts of issues in todays world of API driven relief sizing!  Don't do this to those that follow us!
#5 Ibnu84
Ibnu84
  • 20 posts
Posted 19 June 2015 - 12:21 AM
As per norsok P-001, where no overflow line the tank need to be design full of liquid upto the vent line.
Well, should i say that the tank design pressure is 0.07 barg with a note saying that for thickness calculation a static head of 6 m shall be considered.
Any body knows whether PED apply to this tank?
#6 shan
shan
  • 692 posts
Posted 19 June 2015 - 07:02 AM
You are confused tank design pressure with tank shell stress.
