There are five LPG bullet tanks that will be arranged as shown in the attached diagram. LPG will be unloaded into the tanks from trucks using a pump and pumped out using another pump. The tank is elevated 5 ft off the ground and the fill/suction nozzles of the tanks are spaced 15 ft apart. Here are my questions:
1) Is it a recommended design to have a vapor equalization/return line that connects the vapor space of the bullets to the truck vapor space? I understand it expedites the unloading process by equalizing the truck pressure with the tank pressure, instead of losing pressure in the truck and building pressure in the receiving tank(s), but was wondering if all tank trucks/trailers have the capability to hook up vapor line to their tank.
2) I need to decide whether to fill one tank at a time or fill them simultaneously. If the tanks are filled simultaneously, would an even level maintained in the tanks? Level would be equal in the tanks prior to the start of filling, but I suspect the friction losses in the piping will force most flow into the closer tanks, and least into the furthest. But then this would be counteracted by the higher static head in the closer tanks...What am I missing?
3) Similarly on the pump-out side, if you take suction from the 5 tanks at the same time, will the pump pull equal amount from each bullet and the tank level will be more or less even?
Any insight would be appreciated.
Edited by nybrla, 05 June 2016 - 12:22 PM.
