In HTRI Vibration analysis how following values are calculated.
1. Length for natural frequency
Posted 23 November 2016 - 11:38 PM
Posted 11 December 2016 - 05:47 AM
the TEMA maximum span can be calculated from the TEMA Standards ver 9.0. HTRI uses 80% of the TEMA calculated spans as the max allowable before generating a warning. For the Natural frequencies you can please check the HTRI elibrary. Unlike other softwares, HTRI calculations are openly provided in the eLibrary and you can try and calculate everything on a spreadsheet.
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , 30 Apr 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
