In order to run a hydrostatic test of a piping installation, a practical engineer would never attempt to "fill" the entire piping system with a positive displacement pump meant to raise the pressure in the piping.
What an engineer would do would be to fill all of the piping system to be tested (presumably the stated 100 cm3) with a conventional, low pressure discharge centrifugal pump - which can carry out the filling operation quickly and efficiently. Once the piping system is filled with NO COMPRESSIBLE AIR OR GAS POCKETS, then - and only then - is the positive displacement, piston pump used to raise the pressure in the system from 0 barg to the desired 700 barg. The time required to raise the hydrostatic pressure is minimal and should not be a concern. It is common sense that a relatively small capacity piston pump is not the proper type of pump to fill a hydrostatic system for the purpose of a pressure test. A hydrostatic test involves only hydraulic pressure and, as such, only involves the pressure imposed on a liquid-filled system - in a slow, deliberate manner.
What should be a concern here is the technical and engineering understanding of what is going to take place as well as all the required safety procedures that should be prepared before hand and carefully reviewed and hazoped.
