Removing Sand And Fines From Water
#1 fai1994chemng
fai1994chemng
  • 7 posts
Posted 06 February 2017 - 02:08 PM
I am currently doing my final year project which is based on a hydraulic fracturing plant in the UK. I am doing research into the design of the part of the plant that deals with the flow back fluid treatment, and I can't seem to make a decision on what compounds that may need to be removed from this sand/fines/water slurry. I have so far decided that sand, clay (fines), Lead and Mercury need to be removed before the water can be disposed of, But I have also read about other potentials such as aromatics such as benzene and toluene.
Can anybody offer advice?
Also I was thinking of using just a rotary drum-vacuum filter to remove sands and fines, will this suffice?
  • 6,349 posts
Posted 06 February 2017 - 11:45 PM
1)For coarse particles you may consider sand filter ( equipped with back wash) ,
2)  and you may consider Activated carbon to remove organics !
Edited by breizh, 07 February 2017 - 01:16 AM.
