I have a 4 inch pipe with schedule 40 and another with schedule 80 when should I use Schedule 40 & when should I use schedule 80 ?
I can reframe the question is another way , What is the use of having so many schedules for the same pipe size ?
Pipe Size & Schedule
Started by ayan_dg, Apr 30 2008 12:06 PM
Posted 30 April 2008 - 12:06 PM
Posted 30 April 2008 - 12:35 PM
Ayan:
You are spending too much time on theory. Get practical. What are you going to do when you have two fluid streams - one at 100 psig and another at 1,000 psig. Do you think that you would put them into the same pipe rating? Would you put them in Schedule 40 pipe or in Schedule 80 pipe?
Download my workbook on the Crane Tech Paper #410 and read about pipe schedules and what they mean. I try to explain what a pipe schedule is and what it is used for and I did it because I got tired a long time ago of explaining the same thing to green engineers time-after-time. This is an important topic. Don't take it lightly or it will come back to haunt you when you are least prepared to deal with it.
Posted 08 May 2008 - 06:01 AM
Let me explain to you in LAYMAN's language. Sch 80 pipe will have higher thickness than sch 40 pipe. So it will withstand more internal pressure. By definition, Schdule is = 100 P/S.
where P is internal pressure and S is maximum allowable stress at given temp.
Posted 12 May 2008 - 05:42 AM
Hi Viral,
Schdule no. is = 1000 P/S,
Regards.
Regards.
Higher Pipe Line Dia Specification In UnisimStarted by Guest_Praveen Perumandla_* , 27 Feb 2024 |
Sizing Of Cooling Water Pipe LineStarted by Guest_Asif Azeez_* , 08 Jan 2021 |
Gas In Pipe SupportStarted by Guest_Stellaandoor_* , 26 Jan 2024 |
Maximum Nozzle Size In The Api 650 TankStarted by Guest_rudiawan_* , 18 Oct 2023 |
Recommended Velocity For Highly Viscous Liquid In A PipeStarted by Guest_Quimarah_* , 13 Oct 2023 |
