hi,
was wandering if anyone knows where i will be able to find Cp data at pressures higher than 1 atm for Oxygen, nitrogen. Was needing as high as 9 atm.
thanks
bob
Specific Heat Capacity Data
Started by bob789, Feb 03 2009 04:19 AM
Posted 03 February 2009 - 04:19 AM
Posted 03 February 2009 - 07:43 AM
I am not a thermodynamist, but I think that the Cp is not pressure dependant for ideal gas. It is temperature dependant.
Posted 03 February 2009 - 08:23 AM
Bob:
siretb is essentially correct. However, if we are talking academics instead of practicalities, then the variances in the Cp for Nitrogen can seen at:
http://webbook.nist......mp;STUnit=N/m
You can obtain this free information for Oxygen and a variety of other gases as well by starting out at: http://webbook.nist....hemistry/fluid/
Select "View data in HTML table" as your option when seeking results and you will get a tabular listing that can easily be copied and pasted onto an Excel spreadsheet.
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , 30 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
