Location Of Temperature Measurement
Started by SMMK, Mar 29 2009 05:47 AM
Posted 29 March 2009 - 05:47 AM
How far away should temperature sensor be installed after mixing of cold and warm vapor of ethane? The control system functions to maintain warm temperature.
Is there any standard which could be referenced for locating sensors?
Posted 29 March 2009 - 11:36 AM
Manmohan:
It all depends on how effectively - or efficiently - you mix the two streams. The more effective and efficient the mixing, the closer you can approach the final mixture point in detecting an accurate temperature.
There is a trade-off in achieving efficiency: a pressure drop increase. There are proprietary in-line mixers with a minimum of pressure drop that can yield a reasonably accurate final temperature within 6 inches of the mixer's outlet port.
There is no standard - to my knowldege - in establishing in-line or other types of mixers; nor are there standards for locating the final temperature sensing device.
Posted 04 April 2009 - 08:17 PM
Thank You Art
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Temperature Cross Heat ExchangerStarted by Guest_Priolo_* , 12 Aug 2019 |
Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
