Dear Sir,
Will you please explain me the flow characteristics of concentric and eccentric reducer.Which one is better for control valve, why. Please guide me this.
Thanks in advance.
Stu.
Flow Characteristics Of Reducer
Started by stu, Jul 01 2009 10:21 PM
Posted 01 July 2009 - 10:21 PM
Posted 02 July 2009 - 06:54 AM
It depends on your fluid. If there's a chance your fluid will phase separate, choose an eccentric reducer and put the flat side such that the minor phase (by volume) will not accumulate. I.e. if solids will precipitate out and it's rho is heavy, the flat side goes down and if gas will evolve from a liquid, the flat side goes up. If there's no chance your fluid will phase separate, choose a concentric reducer.
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
