 PIPESIZE PIPESIZE
| Question: | Is the NTU method a reliable means of measuring heat exchanger performance? |
| Keywords: | heat,exchanger,effectiveness,ntu,performance,monitoring |
| Answer: | After cleaning, the U-value should be higher and the Number of Transfer Units (NTU) is equal to UA/Cmin where Cmin is the heat capacity of the fluid with the lower heat capacity. The effectiveness could then be determined any number of ways, but you can see one at:http://www.cheresources.com/hteffzz.shtmlI think that heat exchanger effectiveness is not really much more useful than monitoring the decline of the overall heat transfer coefficient with respect to time. Such a graph would show a relatively quick decline in U-value followed by a "leveling off". The U-value at the "level" point could be considered your service U-value. |
| Links: | Link to Effectiveness Article at www.cheresources.com |
					 Bulk Solids Bulk Solids
					 Corrosion Corrosion
					 Fluid Dynamics Fluid Dynamics
					 Mass Transfer Mass Transfer
					 Plant Basics Plant Basics
					 Refining Refining
					 Safety Safety
					 Thermodynamics Thermodynamics
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library Search
   Search FB
