| Question: | What is the most common carrier gas used in pneumatic conveying? |
| Keywords: | pneumatic,conveying,carrier,gas,choice |
| Answer: | While many applications utilize air as a carrier gas, others are not suited for using air. For example, if the substance being conveyed reactions with moisture in the air or is there is a threat of dust explosions, nitrogen is likely choice. |
| Links: | More on Pneumatic Conveying |
