Static Slot Seal
Started by wojtar, Mar 13 2010 11:58 AM
Posted 13 March 2010 - 11:58 AM
Another topic regarding bubble cap tray hydraulics.
Could anyone explain what is that "static slot seal" or "static slot submergence" ....english is not my native language and I'm confused about that. "Static seal" is present in Chemcad tray sizing menu under slot dimensions. I need an explanation in simple words. Default Chemcad value is 0,0127 m.
Regards.
Regards.
Posted 13 March 2010 - 04:03 PM
In just a few words: that is the height of liquid on the tray above the top edge of slots. As shown in the attachment below, excessive or insufficient liquid gradient across the bubble-cap tray can cause cap malfunctioning and reduced performance. The maximum static seal should not exceed 1.5 inch according to several authors so the default value in ChemCAD should be OK.
Also look at: http://www.scribd.co...bble-Cap-Design
Cheers
Cheers
Posted 14 March 2010 - 09:02 AM
Cheers
Thank you for your reply...I thought that liquid height above the top edge of slots depends on tray dimensions and liquid/gas capacities. I have a feeling that it's useless in chemcad. Whatever I specify it steal depends on tray dimensions that I also specified. How should I tell simulator that value??
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panagiotis_* , 23 Feb 2024 |
Gas Seal In Hydrogen Vent StackStarted by Guest_Afshin445_* , 27 Dec 2023 |
Liquid Seal Drum DesignStarted by Guest_maginaga_* , 12 Oct 2023 |
Answered
Flare Seal Drum Blowing Seal Water To Other Side Of Baffle- Loosing SeStarted by Guest_Shamsi_* , 13 Sep 2023 |
