Posted 02 June 2010 - 09:45 PM
Dear Cruam
For sizing a distillation column, the typical jet flooding limits are maximum 85%, minimum 20-30%. While simulating in Promax you can specify maximum limit up to 85%. But this is the maximum recommended for column operation. If you are designing a new distillation column, it is advisable to size for about 60% flooding. The reason is that the column is the main equipment in the unit. Most units undergo expansions, modifications, revamps after a few years of operation. So distillation columns "must" be designed with a good margin so they can be retained for expansions/revamps.
For column sizing, I would suggest you not take a simulation software estimate. If you need to specify something just for simulating the column, you can put anything, but for selecting the column diameter, you shall use dedicated column sizing software, such as KG-Tower and Sultray. In fact, if you have time, it is most recommended that you send a query to a tray vendor (Koch Glitch, Sulzer, or other) and have a rating run by them. Tray vendor can give you the best diameter selection. Alternatively, they give you free software and you can do it at your own.
It is important to mention here that when you use tray rating software, it will ask a foaming factor which is typically 0.8 for general service. For amine Absorber and regenerator, 0.6-0.7 is used. This is very important and affects the diameter selection. Other things, as mentioned by Chellani and P.Engr, shall also be considered.
Sufyan Khan K.K.
