Basic Nozzle Sizing Guidelines
Posted 14 April 2010 - 01:24 AM
Posted 14 April 2010 - 01:43 AM
Here is one design standard for sizing gas-liquid separators, and is available online: http://www.mop.ir/st...pr/e-pr-880.pdf
Cheers,
Posted 14 April 2010 - 01:48 AM
http://www.mop.ir/st...pr/e-pr-850.pdf
http://www.mop.ir/st...pr/e-pr-440.pdf
Posted 14 April 2010 - 09:04 AM
Posted 15 April 2010 - 08:05 AM
Apart from IPS, the NORSOK standards can also be downloaded for free and there are some really good materials in there. Visit: http://www.standard....tors/Petroleum/
Process Design: http://www.standard....Process/P-0012/
Process Systems: http://www.standard....Process/P-1002/
Field Instrumentation: http://www.standard....ntation/I-0011/
Safety and Automation Systems: http://www.standard....entation/I-002/
Piping and Valves: http://www.standard....-Layout/L-0012/
Materials Selection: http://www.standard....aterial/M-0012/
Mechanical Equipment: http://www.standard....chanical/R-001/
Happy reading,
Posted 15 April 2010 - 12:28 PM
Hello! I am currently designing a pressure vessel. My feed is a vapour-liquid mixture that will then get separated. My question is, how do you calculate for the nozzle size for both the inlet and outlet streams? I was wondering if there are basic rules of thumb when it comes to sizing it properly. Thanks!
A standard I had written for a middle east O&G gives the following guidelines for momentum criteria for the inlet & outlet (gas/liquid) nozzles for separators:
Feed Inlet
The function of the inlet device is to initiate gas/liquid separation and distribute the gas flow evenly in the gas compartment of the vessel
It comprises of the inlet nozzle & inlet device, if any.
The diameter of the inlet nozzle is the function of the feed flow rate & the pressure.
The criterion for nozzle sizing is that the momentum of the feed shall not exceed prescribed levels. The maximum allowable inlet momentum can be increased by fitting inlet devices.
The nozzle internal diameter may be taken equal to that of the feed pipe but also momentum criteria shall be satisfied, as per the table given below:
Inlet Device
Momentum
None
rmV2m,in <=1400 kg/m.s2
Half Open Pipe
rmV2m,in <= 2100 kg/m.s2
Schoepentoeter
rmV2m,in <= 8000 kg/m.s2 (Note-1)
Cyclone (conventional)
rmV2m,in <= 10,000 kg/m.s2 (Note-1)
Multi-cyclone
rmV2m,in <= 35,000 kg/m.s2 (Note-1)
Where rm is the mean density of the mixture in the feed pipe in kg/m³
& Vm,in is the velocity of the mixture in the inlet nozzle in m/s
Note 1: Vendor to confirm the values
Gas and Liquid Outlets
After the separation of the gas & liquid phases, the two phases will exit the separator via their respective nozzles.
The nozzle sizing criteria is as below:
Gas
The internal diameter of the gas outlet nozzle should normally be taken equal to that of the gas outlet pipe but additionally the following criterion shall be satisfied.
rGV2G,out <= 3750 kg/m.s2
where;
rG = the density of the outlet gas from the separator
VG,out = the velocity of the gas in the outlet nozzle
Liquids
For new installations the liquid outlet nozzle shall be sized considering velocity below 2 m/s.
Hope this helps.
Posted 15 April 2010 - 11:18 PM
Posted 16 April 2010 - 02:19 AM
- Intensive dispersion of liquid phase into a fine mist (speaking about the feed nozzle) which adversely affects separation efficiency,
- A so-called "sucking effect" in the gas outlet nozzle which can cause upset/dislogding of vessel internals
Hope to hear some more opinions on the subject, especially from mechanical point of view.
Column SizingStarted by Guest_guoyinyanliner_* , 21 Sep 2026 |
In Hysys, For Horizontal Vessel Sizing,Started by Guest_guoyinyanliner_* , 10 Sep 2026 |
Sizing Two-Phase And Three-Phase SeparatorsStarted by Guest_guoyinyanliner_* , 03 Sep 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
