I need your help about how to use the regress Bips in ChemCad. I have the experimental data of VLE of ethanol-water-ethylene glycol system.
I compared the VLE experimental data from the ChemCad and were different, so i need to to do this regression in order to obtain the new bips.
Therefore, I did the regression but i obtained almost the same values of bips that ChemCad has. Attach you can find the comparasion between experimental data and ChemCad.
The other possibility is to edit the bips, i got some bips from the literature but these bips are from the hysys. I used the same bips for
ChemCad 6.2 but my simulation gave me wrong results.
I appreciate your recommendations and your help,
Achso...
