GOOD MORNING.
IS A PILOT OPERATE SAFETY VALVE HAS A BLOW DOWN ADJUSTMENT? IF IT DOES PLS. EXPLAIN TO ME HOW DO YOU PERFORM THE ADJUSTMENT.
THANKS & REGARDS,
ARAFAT
Pilot Operate Safety Valve
Started by Arafat, Feb 18 2005 01:35 AM
Posted 18 February 2005 - 01:35 AM
Posted 21 February 2005 - 08:52 AM
Just by looking at figures 6-10 in API RP 520, I see that at least some pilot operated relief valves (PORVs) have a blowdown adjustment. For example figure 7 shows an adjustment ring at the bottom of the pilot valve, while figure 6 shows a variable orifice in the pilot line.
If your question is related to a specific brand and type of PORV, you may contact the vendor of that valve to ask if and how you can do the blowdown adjustment.
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
